How to create Certification verification system
Status: Closed · Asked by HSE WORLD on · 0 views
How to create Certification verification system connect to pabbly and website like wordpress website any solution please suggest
Hey @Mubarak NH
We suggest that you review the video lesson below, which addresses your specific use case and provides guidance on how to approach the certification process logically.
OK THAT UNDERSTAND
my question is how to certificate verify in other companys
Please briefly elaborate on your concern. For detailed information on a specific company's system, it would be best to consult the company's professionals or a specialized automation expert.
CREATE THE CERTIFICATE THEN HOW TO VERIFY
LIKE WEBSITE TO THROUGH A CERTIFICATE VERIFICATION OPTION THEN ENTER THE CERTIFICATE NUMBER THEN GET ALL DETAILS
Hey @Mubarak NH
Could you please create a short video explaining how you are developing the system and the application you intend to use in your Pabbly Connect workflow?
Whereas you can directly use such WordPress plugins to connect with your certification.
Ok sir
I will try
