How to Filter Out Empty Webhooks
Status: Open · Asked by Sven Bosau on · 0 views
sven-bo — Question ·
I have a workflow that starts with a Webhook trigger (Catch Webhook), followed by a Filter step to filter out empty or invalid webhook requests before they get processed further.
The problem I'm running into is that when I try to configure the Filter step, the "Choose Label" dropdown shows "No fields available in this step".
My question: Is there a recommended way to prevent empty webhooks from being processed in the workflow? Specifically, how can I set up the filter when no fields are available to select?
Any guidance or workarounds would be greatly appreciated. Thanks in advance!
Hi @sven-bo,
You need to capture a response in your trigger step first. Then, use the Exist filter condition to ensure that the next steps execute only when the data exists in the webhook response.
Arshil Ahmad
?Rate your support
