How to find "full example posting string" for webhook?
Status: Closed · Asked by Joel Osborne on · 0 views
Can someone show me where to find this example information?
I would think that this would be easy to find, but I'm pretty new to using webhooks/API's, so I'm not sure what information I need.
I am using a lead service provider which will send the lead data to my email platform via webhook/api. I have already set up the webhook in my Connect workflow, and it works. This is the flow:
1. Trigger: Webhook
2. Action: Selzy (my email platform) - subscribe to list
The workflow works.
But now as I set up my account with the lead platform, they are asking me to provide them some information so that they can set it up on their end. This is what they are asking for:
"provide a full example posting string (including both base URL and parameters) as well as the response we should get for a success."
Is someone able to help me with getting this information? Where do I find it? I have already sent them my webhook URL.
Thanks!
Hey @Joel
Can you please tell us what base URL you want regarding your API request and the complete use case you are looking for?
Do you mean the URL from Selzy (email platform)? If so, here it is:
https://api.selzy.com/en/api/subscribe?format=json&api_key=KEY&list_ids=1&fields=
[email hidden]&fields[Name]=John+Doe&double_optin=3I am using a lead provider to send contacts to my email platform. The lead provider should be sending the [ email ] and [name] of the contact/lead to my email platform. The lead provider is asking for that information from me so that they can set up the API on their end (they haven't used Pabbly) before. But I am getting confused. I thought they only needed the Pabbly webhook string.
Hey @Joel
Please check the following screenshot once we have created the endpoint URL regarding your API request for Selzy.
Else, you can simply use the following action step.
Thanks for your reply. FYI, I did not your "else" step ("subscribe contact to list"), and the workflow did work.
This is why I am confused. I'm not sure what the lead provider is asking for, or if I just don't understand correctly because I am not familiar enough with webhook/API's.
I have asked them to confirm what they need.
