How to fix Generic Error?
Status: Closed · Asked by akshey on · 0 views
akshey — Question ·
kindly tell me how to fix the Generic error in the WhatsApp cloud API.
PabblyMember4 — Reply ·
Hey @akshey
Could you please click on Connected again in your Whatsapp Cloud API and click on Save button and then try?
If you are still getting the above error message then you can again click on Connected button >> Click on Add New connection and enter all the details and then click on Save options and again do the mapping. After this step kindly click on Save and test button. It will work for you.
Kindly let us know if you have any questions or comments.
Kunal
akshey — Reply ·
akshey — Reply ·
I have one more question.. could you please tell me where to check replies from users?
akshey — Reply ·
I cannot see the messages since I don't know where to read them. Kindly tell me where to reply to them because my WhatsApp is also not signed in after it is linked to meta's cloud API.
Hey @akshey
You should check the same from the WhatsApp Cloud API since the message was being sent and received from their end.
ajikgung — Reply ·
Hi, I try to reconnect and set up new connection also, but generic user error is still happens to me. Can you help?
We have replied to your query on another thread. Please check that out.
