How to fix Sensorpro error
Status: Closed · Asked by aaronocampo on · 0 views
Trying to add a subscriber in Sensorpro from a form submission from a Webflow project and getting this error:
And not being able to find the lists from Sensorpro to add the subscriber to that list.
Hey @aaronocampo
Kindly try re-connecting your Sensorpro's account with the action event and make sure you have passed the correct credentials which you are using.
Hey @aaronocampoKindly try re-connecting your Sensorpro's account with the action event and make sure you have passed the correct credentials which you are using.
I re added the credentials now. Thanks for looking into it.
