How to generate an encrypted key with Pabby?
JeffreyYu
Trying to use Pabbly to encrypt/hash some query parameters. E.g. change
APPLE123
To something like
Sjch68:&$hdnc870
In particular, I want to generate a randomized key per unique request.
Is there a built in action step for this? Or should I use Python’s Code step?
ArshilAhmad
Moderator
Hi @JeffreyYu,
You can try using Data Transformer to achieve your use case.
