How to Get Phone Numbers from TagMango to Aisensy
Status: Closed · Asked by Ambili Menon on · 0 views
Ambili Menon — Question ·
I have my landing page and sign up form on TagMango platform.
I have Pabbly Connect and AiSensy.
I need help on how to send the mobile numbers of new leads to my AiSensy Contacts and have a Template message (e.g. Welcome to the community" sent to them automatically.
Please help me build the TagMango -> Pabbly -> AiSensy workflow.
Thank you so much :)
Hi @Ambili Menon,
Please follow the steps in the video below to set up TagMango as your trigger application and capture lead form responses. Only the first half of the video is relevant for you.
youtube.com/watch?v=4N7_SI835sg:171
Follow the steps in this video to set up AiSensy as your action application to send template messages. Only the second half of the video is relevant for you.
youtube.com/watch?v=-XYT3GibuEY:173
Ambili Menon — Reply ·
Thank you Arshil, let me go through these videos fully and try to create it.
One quick question, for every new workflow when i click "Connect" do I always need to "Add a new connection" or can i use "Select Existing Connection"?
Hello @Ambili Menon
Yes, you can use the "Select Existing Connection". Please make sure to use the same connection for an application throughout the workflow.
For example: If you have used Facebook 4 times in a workflow, please make sure you are using the same connection
Thank you so much for the solve.
It's working perfectly!
Hello @Ambili Menon,
