How To Impelement POST API
Status: Closed · Asked by zeegarpatel on · 0 views
zeegarpatel — Reply ·
JamesColin — Reply ·
Are you sure it is a POST ?
The example you show is a GET since the arguments are in the URL.
Try it with a GET like you did with the parameters.
You don't need the ? at the end of your endpoint URL.
Now it shouldn't return an error.
Hey @zeegarpatel
Kindly try passing the endpoint URL in this format with the POST method-
https://wazolo.com/api/send.php?number=123456&type=text&message=test message&instance_id={{ instance_id }}&access_token={{ access_token }}
Further to get the access_token please check out the following screenshot -
Thank you so much for your reply
