How to integrate with NoCRM.io
I am trying to integrate a Formidable Form with NoCRM.io in Pabbly Connect using the existing NoCRM.io action "Create Lead", so when a new form is submitted in FF, a new lead is created in NoCRM.io, filling some personalized fields I have defined insice NoCRM.io (8 fields, see screenshot).
I can not see the option to map name, email and phone number fields into the NoCRM.io custom fields with this action, is this possible? If not, how can I map my 3 fields into the existing equivalent custom fields inside NoCRM.io? Shall I use a generic API invocation to NoCRM.io API in this case? If yes, where can I understand how to do it?
Thanks.
Javier
Hi Ashil
But creating a user is not what I need, a NoCRM.io user is a user to the tool, not a new prospect.
I am trying to create a new prospect, let's say a new lead, or a new customer, and I want to be able to store their details (name, surname, age, etc).
Thanks in advance,
Javi
Active member
Hello @Javier Pabbly
The use case you are trying to acheive doesn't seem t be possible as the NoCRM.io API doesn't provide any endpoint to create a lead with the Custom fields. Although you can add the required data under the description field.
