How to integrate with Shopia ?
Status: Closed · Asked by Joyce Cheung on · 0 views
I note that Pabbly can newly integrate with Shopia ? Is there any link or guide that can give me idea what is the use case ? Any link or guideline that show me the integration and set up ? Thank you.
Hey @ysc711
Kindly try the action step once in your workflow as mentioned in the helptext.
Do, let us know if you get stuck at any step.
The output language is working for you? In case it is not English.
When I try to put the language in the box "Output Language" it shows me the result of data I collected in the previous steps and don't let me choose an output language, if I type the language I want (Portuguese (Brazilian)) it doesn't work. If I do not fill this field, it works, but comes in English. I have already configured my Shopia to output in Portuguese.
Hey @Ricardo
As per the conversation with our integration team, they have said that the integration on the platform was integrated by their team on the platform.
So, we recommend you reach out to Shopia's development team and share your concern since they will help you with your concern accordingly.
