How to keep common endpoint url in one place and use everywhere
Status: Closed · Asked by Deependra Kumar Gupta on · 0 views
here in the below picture the highlighted url is used in every action route. Only /add-contact part will be changed . Then how to keep common url in one place and access using dynamic variable . so that if i change route in one place then it will be reflected everywhere.
Hey @Deependra Kumar Gupta
As discussed during the meeting with Ashish and Nivesh, you can set up this by following the below procedure:
Go to Action section and configure it like this
Additionally, if you didn't understand, we can schedule a call again or you can share this app with our developer and he can set it up for you.
