How to receive order alert to my WhatsApp from woocommerce
Status: Closed · Asked by digitalaru on · 0 views
digitalaru — Question ·
digitalaru — Reply ·
I dont want to send order details to customers but I need to get notification to my own whatsapp number if some order product from mywebsite
PabblyMember4 — Reply ·
Hey @digitalaru
You can give your number manually in place of adding a phone number for the customers. Kindly note that the video is showing to use the Chat API for Whatsapp but we have deprecated the Chat API. You can use the other Whatsapp tool for sending messages. You can check the below link for checking all the available Whatapp integrations - https://www.pabbly.com/connect/integrations/
i can't find Chat Api as per the video
Which is the best for order alert Api integration tool
You can go with Dialog360, Whatsapp cloud API, WATI as per your requirement. All of them are doing the same work.
Kindly check all the available integration tools at https://www.pabbly.com/connect/integrations/
Hey @digitalaru
Could you please share the email id associated with Pabbly account to check the details?
[email hidden]
Kindly make sure that your number must be verified with the Whatsapp cloud API else it will not work.
how to verified customers numbers in whatsappcloud api
It seems like you have not generated a permanent token for your Whatsapp API. Please check the video for generating a permanent tokens so that you will not be encountering this issue again.
youtube.com/watch?v=y2beqnlim6g
