How to "Run Actor" with the Apify connection?
ArshilAhmad
Moderator
Hi @SmartMarketing,
Currently, we don't have the 'Run Actor' action event available for Apify. If you would like this action event to be added to Pabbly Connect, you can submit your request on our dedicated platform:
https://pabbly.featureos.app/b/Update-Existing-Application
Our integrations team will review your request and, if possible, add the desired action event to Apify.
In the meantime, you can try using the API by Pabbly module to execute this endpoint and see if that helps you achieve your use case.
https://docs.apify.com/api/v2#tag/ActorsRun-collection/operation/act_runs_post
