how to select a part of body text from email to discord
Status: Closed · Asked by adam2021 on · 0 views
how to select a selective content of the email and send it automatically to discord ? however, there is only an option " body text" to click on Pabbly
can i only select a part of content in the body text? I would like to keep blue content and delete yellow content
Another question
When I forward email content from email to telegram and appear this error how to fix it?
Hi @adam2021,
You can add a Text Formatter to your workflow to extract the relevant data.
Please try mapping only the Blue part in the Telegram action step, and see if that fixes the issue for you.
Hi @adam2021,You can add a Text Formatter to your workflow to extract the relevant data.
Yes done it thanks a lot
