How to send Album to telegram with Post
Status: Closed · Asked by luabrankatz on · 0 views
I was wondering how can i upload a photo album with a post attached to it.
Right now what I can do is just to upload an album only.
This is how i want it to look like:
Hey @luabrankatz
We have forwarded your concern to the technical team and they are looking into it.
Hey @luabrankatzWe have forwarded your concern to the technical team and they are looking into it.
The final idea of this function is that when ever I send an album i will be able to send it with the post attached to it so the user will understand that the post referring to those photos.
so right now the solution is to send in 1 message the album and in a following message the post so then the user see 2 messages instead of only one and me hoping that he understand that this post is referring to the album that was sent before it.
I think that the change that you will make will also reduce the usage of your servers because it will require 1 less API trigger. (multiply it by thousands of pabbly users that each one of them trigger thousands of times)
Yes, we are checking on the action step to send multiple images at once.
the option to send multiple images at once is available by using the action "send album to telegram"
the option that i am looking for is to add a post attached to those photos similar to the photo that i attached
For this requirement, our team is already working on it and shall notify you once it gets updated.
Hey @luabrankatz
Our team has reviewed your use case, and we were unable to find a way to pass the images in the format you described. Therefore, it seems that your use case is not possible.
