How to switch from Pabbly Plus to Connect
Status: Open · Asked by Support on · 0 views
Hemant — Question ·
I currently have Pabbly Plus monthly plan. How can I switch to Pabbly Connect.
If it requires me to cancel my existing susbcription and buy new one for Pabbly Connect, then will it stop any automations running currently?
Can I expect anything else to be impacted because of this transition?
Hi @Hemant,
Could you please share the email address associated with the account for which you’re looking to switch the plan?
Hemant — Reply ·
Hi @Hemant,
[email hidden]
Hi @Hemant,
Upon checking the Pabbly account associated with the email you provided, please note that you are not currently subscribed to any active Pabbly plans. The subscription visible under your account is in a pending state.
You may proceed with purchasing the required Pabbly Connect plan accordingly. There will be no impact on your existing workflows, as there is no active subscription associated with your account at the moment.
Hemant — Reply ·
Hi @Hemant,
Thank you, Preeti. I'll purchase it. But I don't see any option to go for monthly subscription. I only yearly, 2-year and 3-year plans. How can I purchase a monthly plan?
Hi @Hemant,
You can find the monthly plans on the same page at the bottom under the Frequently Asked Questions section.
https://www.pabbly.com/connect/#pricing/
