How to Switch From Zapier
Status: Closed · Asked by ChristianL on · 0 views
ChristianL — Question ·
To switch from Zapier do I create all the processes with Pabbly Connect, make sure they are working, and then turn of the Zaps OR should I turn off the Zaps before connecting and testing the Pabbly Connect?
Fagun Shah — Reply ·
You should setup the test workflows first in pabbly and if they work only then turn off the zaps.
Fagun Shah
- Automation Freelancer
ChristianL — Reply ·
thank you!
