How to trigger Robomotion using Pabbly connect ?
Status: Closed · Asked by Maheshwara on · 0 views
`Robomotion RPA URL https://docs.robomotion.io/reference/api/
i am trying to connect it showing error
Hey @Maheshwara
Regarding your concern about the error message, we would recommend you contact their support team. As we can see it has been set up correctly, but from their application, you are getting the "no_permission" message.
Even if you tried the same in the Postman application, you will face the similar error message in its response.
Thank you from your support
