How to use the text formatter module to replace multiple values with blank?
Status: Closed · Asked by Juan Colicchio on · 0 views
Juan Colicchio — Question ·
I'm only aware that the module can only find and replace one string at a time. Would it be possible to replace apostrophes, commas, forward slash, or periods with blanks using only one module instead of four?
Fagun Shah — Reply ·
Actually it should be possible using SUBSTITUTE formula in Number Formatter -> Spreadsheet Formula. But it is buggy in pabbly connect. They need to make it proper. here is the example in gsheet which works proper.
And here are results in Pabbly Connect's New and Old Number formatter(both are not working properly) -
Fagun Shah
- Automation Freelancer
