How to VOID and DELETE a Pass in Passcreator
Status: Open · Asked by BeautyCouncil on · 0 views
I have a webhook that successfully marks a Pass VOID in Passcreator, but does not Delete it.
I tried to add a second step in Pabbly below the VOID action step to use the same connect to Passcreator from the previous VOID step. The field "Wallet Pass Identifier" is not turning off the "required" notice when I add in the field the same way from the template.
Can I not stack these two? Do I need to create a separate workflow? Can I not use the same connection to Passcreator?
Attached is my working VOID step.
Thanks!
Hi @BeautyCouncil,
Hello @BeautyCouncil,
Thank you for your query.
However, we would like to inform you that Passcreator is a user-generated application within Pabbly Connect. We recommend reaching out directly to the app creator regarding any functionality requirements or limitations, as they would be better positioned to assist you with this specific case.
[email hidden]
