How to write parameters in Facebook Conversion API
Status: Closed · Asked by seminare_sk on · 0 views
I try to connect my shop with Facebook conversions API. At "send purchase event" as an action in "Facebook Conversion API" there is a field called "Event name".
There is a link right there where I can refer to Facebook to see which events I can add, in my case "purchase".
Regarding to the Facebook-site, I have to define parameters for the purchase event, like currency and value.
How do I enter this in pabbly correctly?
Thank you!
Hey @seminare_sk
In the Facebook Conversions' action step, you can only pass the Purchase in the Event Name fields. Currently, other events are not available to use.
Hi, I changed that, but I do not get any new data from the sending webhook. I click on "re-capture response" and do a purchase, but the "waiting response" button does not change. I even deleted the workflow and started fresh, but I do not get any data despite the fact that the webhook is visible and active in Elopage.
Hey @seminare_sk
As we can see from your workflow( elopage Nach FB Conversions API ), you captured the webhook response correctly.
Further, we checked your history log and it is also capturing the use case.
