Hub Spot to Gsheets
Status: Closed · Asked by swallis77uk on · 0 views
I am trying to create a workflow with the following
1) On Hubspot - Contacts - Assessment Confirmed if yes then add to spreadsheet
I have tried using various techniques but it does not seem to be working, any suggestions for this, please?
Hey @swallis77uk
For your specific use case, I suggest using the router in your workflow.
The router can assist you in filtering the data based on specific conditions, allowing it to run only when it contains "yes." Please refer to the video tutorial below on how to use the router and then proceed from your end:
Excellent thanks :)
