HubSpot 2 Way Sync
Status: Closed · Asked by David Ho on · 0 views
david — Question ·
How can I use PC to add/delete/update contacts in HubSpot? Is that possible?
Use case:
Add/delete/update of contact on Jelly Reach > Pabbly Connect > HubSpot
Add/delete/update of contact on HubSpot > Pabbly Connect > Jelly Reach
How can I use Pabbly Connect to achieve the above use case?
Hey @david
In order to develop automation, practically all action steps are available, with the exception of the Hubspot Delete Contact action step, which is not available. Please post your request to add this action step here: https://pabbly.hellonext.co/
Our integration team will investigate it and add it if needed.
