HubSpot and Pabbly
Status: Closed · Asked by S7Growth on · 0 views
S7Growth — Question ·
We are new to Pabbly and we appreciate any help in trying to implement the following use case:
Use Case: "When lead status is changed in HubSpot then trigger a specific WhatsApp drip sequence with images and pdf files"
The drip sequences details can be stored anywhere, for example, we can put it in Google sheet.
For example when Lead Status = "New" then trigger "New Sequence"
  1. Message one with pdf file and image will be sent 2hrs after the change
  2. Message two with pdf file and image will be sent 3 days after the change if no update in the "lead status" in HubSpot
  3. Message three with pdf file and image will be sent 5 days after the change if no update in the "lead status" in HubSpot
  4. Any replies from the customer will be updated in HubSpot activities field
Thank you
Fagun Shah — Reply ·
Pabbly has trigger called Contact Updated for Hubspot.
For whatsapp drip sequence you will require any one of official or unofficial whatsapp API.
Like 360dialog or Chat-API or WATI.
Fagun Shah
- Automation Freelancer
S7Growth — Reply ·
Thank you. What about for Whatsapp inbox, what would you recommend?
