Huge Problem with Task Firing hundreds of times!
Status: Closed · Asked by omarei on · 0 views
I followed instructions from your videos and linked google sheets with OpenAi and whenever the webhook send event function hits, it consumed over 200 tasks in a couple of seconds. There seems to be a bug, this is not an issue with the workflow itself because i deleted it all thinking it was an error on my part, then i fired off another test and it flew from 500 to 800 tasks used up. This is a massive issue it also shot up my openAI usage from 4$ to 10$ in a matter of seconds. Please advise.
Is it possible that the webhook is conflicting with another workflow that exists? If so, how can I use google sheets in multiple workflows if the webhooks overlap? I am just guessing, but need to solve this soon since this is part of a larger project I am building. What do i do about the hundreds of tasks this issue used up?
Hey @omarei
Can you please explain your concern briefly on how you are getting the response, along with the name of the workflow?
Hi there,
I had a task set for Google Sheets to OpenAi with webhook link https://connect.pabbly.com/workflow/sendwebhookdata/IjU3NmMwNTZkMDYzZTA0MzY1MjZiNTUzMyI_3D_pc
this workflow blew up my task number, there seems to be a strange glitch with the sheets extension that would have completely finished all my tasks and limits on both Pabbly connect and OpenAI.
Please check your other thread for a similar query.
https://forum.pabbly.com/threads/huge-problem-with-task-firing-hundreds-of-times.11841/
Hello
Could you please assist this same problem occurred with a WhatsApp Workflow I'm setting up during testing and it consumed all my tasks.
Can you please share the workflow URL in which you have tried the same so that we can look into it and help you accordingly?
Hi Supreme
Please see workflow URL;
https://connect.pabbly.com/workflow/sendwebhookdata/IjU3NjUwNTZmMDYzNjA0MzA1MjZhNTUzMTUxMzAi_pc
I was testing it this morning and it fired up all my remaining tasks.
Please can you have a look and let me know.
Regards,
Please see workflow URL;https://connect.pabbly.com/workflow/sendwebhookdata/IjU3NjUwNTZmMDYzNjA0MzA1MjZhNTUzMTUxMzAi_pc
I was testing it this morning and it fired up all my remaining tasks.Please can you have a look and let me know.
It seems that within your workflow using the WhatsApp Cloud API, you've established a loop where the response you're receiving is the same as what you're sending.
Moreover, we've gone ahead and reset all your tasks temporarily. Please refrain from utilizing a loop-based workflow that could result in depleting your task resources.
It seems that within your workflow using the WhatsApp Cloud API, you've established a loop where the response you're receiving is the same as what you're sending.Moreover, we've gone ahead and reset all your tasks temporarily. Please refrain from utilizing a loop-based workflow that could result in depleting your task resources.
Hello Supreme
Thanks a lot for that. My dashboard still shows all tasks consumed.
Kind Regards,
Please check now!
