I am not able to send messages even using send on event
Status: Closed · Asked by Param on · 0 views
Param — Question ·
is there any way to solve this problem?
Hey @Param
Could you please tell us that the data in your Google Sheets are coming from a third application except Google's or you're manually feeding on it?
If you feeding data manually on the Google Sheets then use "Send on Event" or if the Data is coming into your Sheets from another application, please select "Send on Event" and "Auto Send on Schedule" in the Pabbly Connects' Add-on.
