I can't figure out how to use Pabbly and Jobber
Status: Closed · Asked by greenfox on · 0 views
I created a webhook for GoHighLevel so the trigger is done.
But Jobber is not an app in Pabbly. The info I found on this forum is old info - screenshots of Pabbly instructions say use a webhook from Jobber account, but I can't find any webhooks in the client's Jobber dashboard.
Whats the solution?
Also no webhook as the next step?
Hey @greenfox
We are afraid that there are no action steps available for "Jobber". It can only be used for trigger.
Additionally, since webhooks serve as trigger events, they are not available as actions. However, if you wish to transmit your data to another application or workflow within Pabbly Connect, you can utilize the "Data Forwarder" module.
