I have a question for connecting Stackby To Flowlu, I have a detailed example.
Status: Closed · Asked by anucha adsin on · 0 views
humantab — Question ·
I'm having trouble creating automation to work with my data.
In the Custom Fields section of the CRM Organizations section.
When I use the api in pabbly connect, something is incomplete, i.e. there is no Custom Fields I created.
because I have to heart I'll put the values in the Custom Fields I created with Automation.
I attached a ready sample A sample video is here for you to watch.
Hey @humantab
We are currently looking into it, kindly allow us some time.
Regards
humantab — Reply ·
thank you.
Hey @humantab
Our integration is currently looking into the possibility to add the custom fields in the action event. So, please give us some time to add the custom fields to it.
Hermes — Reply ·
@humantab Pabbly displays the custom fields that are created under all accounts. I see you dont have the ability to create custom fields there
Best regards,
[EMAIL='[email hidden]']Hermes[/EMAIL]
Connect with me on LinkedIn
humantab — Reply ·
Hey @humantab
Thank you very much. This part, I believe it will be a great addition to automation.
I will wait
