I have a Tag in LeadConnector V2 that is being split into two separate tags
Status: Closed · Asked by Reach Your Peak on · 0 views
I am adding a tag, [ppc]new lead in the "Create or Update a Contact" action for LeadConnector V2.
Pabbly seems to be treating the right bracket ] as a comma and is separating the result into 2 tags - [ppc] and new Lead
Here are some additional details: https://www.loom.com/share/99892954eaa948d3be1480663a5badc9?sid=1cd090f5-2306-4e17-9a23-6739ec11fb52
Thanks in advance for any suggestions (other than use something other than left and right brackets - :) )
Hey @Reach Your Peak
I have forwarded your concern to the technical team and they are currently looking into it.
Regarding your concern, our technical team requires some details about the specific use case in which you're encountering the need to include square brackets. Providing this information will assist us in addressing your concern more effectively.
Could you please share insights into the specific use cases being used for the implementation of square brackets in your tag field?
