I need a XOLA connection, is that possible?
Status: Closed · Asked by rafaellaeraignacio on · 0 views
rafaellaeraignacio — Question ·
Hi I need a xola connection where I can get the new bookings and customer info and integrate with our CRM and Slack.
https://www.xola.com/
Arshita — Reply ·
Hey @rafaellaeraignacio
Currently, we don't have any integration with the Xola application. If you want to request for building up new integrations, please send us the request here and upvote it - https://pabbly.hellonext.co/b/Integration-Request. We prioritize the integrations based on the number of upvotes received for the application.
You can check for the available application with us here- https://www.pabbly.com/connect/integrations/
However, if the Xola application supports Webhook or API then you can use Webhook or "API by Pabbly" module and can connect it and fetch the data.
