I need help on how I can add user automatically to an existing calendar on gohighlevel through webhook on pabbly
Status: Open · Asked by Marvey34 on · 0 views
I need help on how i can configure the workflow action on pabbly so that it add users that fills out my form to my calendar and swt them up as a staff that can attend to appointment from my customer.
Hi @Marvey34,
Currently, we don't have the action event to create an appointment in GHL. If you want this action event to be added to Pabbly Connect, you can submit your request on our dedicated platform:
https://pabbly.featureos.app/b/Update-Existing-Application
In the meantime, you can try executing this endpoint to achieve your use case:
https://highlevel.stoplight.io/docs/integrations/a192f863cad27-create-appointment
