i need help thrivecart-systeme.io / add contact + add tag
Status: Open · Asked by stef on · 0 views
stef — Question ·
Task History ID: IjU3NjUwNTZhMDYzNTA0MzY1MjZiNTUzMDUxMzY1MTYzNTQzMTBmMzAi_pc
I'm having trouble with my workflow.
It gives me an error at the last step when it comes time to add the tag to the new contact that was just created in the previous step.
I've attached screenshots and the error code provided in the notification email. :
Step Name: Systeme.io > Add Tag to Contact
Connection Name: Systeme.io #1- pabblyaxia
Task Error Detail:
"type": "https://tools.ietf.org/html/rfc2616#section-10",
"title": "An error occurred",
"status": 404,
"detail": "Not Found"
Hello @stef,
Please refer to the attached image to know better about the issue and how to resolve the same.
