I need help with the connection of activecamping and woocommerce
Status: Closed · Asked by shoppig on · 0 views
shoppig — Question ·
I already connect woorcomerce it works fine to receive an order but the problem comes when I try to add that new user to an activecamping list
I get this error ?
Hey @shoppig
We looked into your workflow and it seems like in the "ActiveCampaign: Add Contact to a List" action event, you have mapped all the contact details instead of the Contact Id of the user which is already mentioned in the help text beneath the respective field.
Kindly map the Contact Id with the help of the "ActiveCampaign: Search Contact" action event. Please check out the following screenshot for a better understanding.
