I need your help with Tidycal and Twilio
Status: Closed · Asked by Phong Minh To on · 0 views
windcvs — Question ·
Hi Pabbly Connect team,
I need your help to build a workflow like this one for my nail salon:
1. I'm using Tidycal for customers to book online appointments, and I'm using Twilio to send them SMS/MMS. I need your help to build workflow when a customer book an appointment, it will trigger Twilio send a SMS reminder to customer an hour before the appointment time.
2. I want to send to customers an Feedback form from Google form after 2 hour of their appointment time.
Hi @windcvs,
https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTZmMDYzZjA0MzE1MjZlNTUzMTUxMzMi_pc
I have cloned your workflow (do not enable or use this) and made some changes to achieve your desired use case. You can make the same changes to your original workflow. You will need to select the application through which you want to send the feedback form and add that application as the last step of your workflow.
windcvs — Reply ·
I did the same with Clone what you created but it doesn't send me a message SMS 1-2 hours before the appointment time. Can you check it please.
Please enable your workflow and schedule a test appointment with starting time for 2 hours from now. Monitor your workflow to see if you receive a message within the next 2 hours. Please let me know as well.
Please do not disable the workflow without letting me know while we test this use case.
