Infobip and Pabbly
Status: Closed · Asked by Darko Slovsa on · 0 views
Darko S — Question ·
Hi Guys,
need connection beetwen Go High Level and Infobip with Pabbly.
I have this in Zapier but i wont this with Pabbly.
1. Webhook action, and send SMS over Infobip
How i can do this?
Arshita — Reply ·
Hello @Darko S
Currently, we don't have any integration with Infobip. If you want to request for building up new integrations, please send us the request here and upvote it - https://pabbly.hellonext.co/b/Integration-Request
We prioritize the integrations based on the number of upvotes received for the application.
However, if Infobip supports Webhook or API then you can use Webhook or API by Pabbly module and can connect it and fetch the data.
Darko S — Reply ·
I Try it but dont work... i become respond, API work, but message is dont sendet. In zapier work perfectly
Darko S — Reply ·
When i change API to Action Event POST ( because i wont that INFOBIP send message to customer ) i become this respond, but message is not sending.
Arshita — Reply ·
Hey @Darko S
I kindly request you to refer to the video tutorial provided below, which explains how the API by Pabbly works. This tutorial can be a valuable resource to help you understand the basic functioning and features of the API, which will be useful in setting up the Inobip API.
Once you have watched the tutorial and familiarized yourself with the API by Pabbly, I would recommend proceeding with the setup of Inobip API with the help of the video.
youtube.com/watch?v=M-oU-yG-CCU
youtube.com/watch?v=bmf4och_kTk
