Instagram Posts - //n
Status: Closed · Asked by Graffiki on · 0 views
Hi everyone :)
I'm automating my blog posts using Airtable and then using the IG module to post. All is working well, but I keep getting //n in the text.
I've tried using Replace before and also turning the caption from Airtable to HTML, but both didn't work.
I was wondering how I can get the text to not have the //n but still be formatted like it is in my airtable (eg. line breaks, etc)
Any guidance is appreciated as I have to go in a manually delete the //n everyday ?
Thanks!
Adam
Hey @Graffiki
While posting over Instagram, if you ever face an issue that //n is also posting out, then you can make use of a data transformer to fix it -
Here's the screenshot showing the same how to make use of data transformer for removing //n -
Thanks for answer Supreme, I have tried that and here is my result, perhaps my setup is wrong?
Please review the 'Replace Keyword' you've used; you have entered a forward slash instead of the required backslash.
Kindly refer to my previous message once and then try accordingly.
Wow, what a rookie error ?
Thanks for being patient with me hahaha I appreciate the help ?
Thanks for the update!
