Instamojo Integration Guide
  • Thread starter Deleted member 12173
  • Start date
Instamojo Integration Guide​
Once you have purchased the plan of Pabbly Subscription Billing, you want to integrate Instamojo payment gateway.
Follow the below steps to integrate Instamojo payment gateway with Pabbly Subscription Billing
Step 1: Login To Your Instamojo Account:
In order to integrate Instamojo payment gateway in your Pabbly Subscription Billing account, you have to log in to your Instamojo account.
Step 1: Enter the 'Login Credentials'
As you click on 'Login' you will be redirected to the below page where you need to enter the 'Credentials':
Now, after successful login you will be redirected to the homepage
Step 3: Click on the 'API and Plugins':
Here, you will get the 'Private API Key' and 'Private Auth Token' which you need to enter in the Pabbly Subscription Billing account.
Step 4: Now, log in to your Pabbly Subscription Billing account and navigate to Settings > Payment Gateway Integration. Here, search for the Instamojo Payment Gateway and click on 'Connect Now'.
As you click on 'Connect Now' it will give the option to integrate Instamojo with Pabbly Subscription Billing.
Step 5: Enter the 'Private API Key' and 'Private Auth Token'
Step 6: Instamojo will be integrated successfully
Similar threads
D
  • Locked
  • Article
Replies
0
Views
1K
D
D
  • Article
Replies
0
Views
969
D
D
Replies
0
Views
730
Deleted member 8616
D
D
Replies
0
Views
2K
Deleted member 9923
D
