Integration failure for symbols
Status: Closed · Asked by amberrockey on · 0 views
amberrockey — Question ·
I had a form submission fail to pass through the integration because there was a . in the name Br.Benet is it possible to have this go through without issue?
Hey @amberrockey
Regarding your concern, you can use the Text Formatter action step to replace the. with a space in live automation.
Since the Constant Contact application is not accepting the . in name and because an issue is coming.
Kindly try the following at your end and let us know if that helps you out.
