Integration Help
Sari
Hi, i would like to know if it will be possible to integrate smartsheet form with google sheet or vice versa. There are few more things which i want to enquire before subscribing.
I would like to get on a zoom call to understand if it will be possible so that i can go ahead with the subscription.
Hey @Sari
You can refer to the following video tutorial for your better understanding.
(Watch the 1st part of the video to capture the data from your Smart Sheet which was filled manually but you can capture it by filling the Form)
Hope the above information helps. Let us know if you stuck at any step while building the workflow. We will assist you accordingly.
