igonaldo
Subject: Integration Issue: Yampi & Systeme.io - Working in Tests but Not in Production
Dear Pabbly Support Team,
I'm experiencing an integration issue between Yampi and Systeme.io through Pabbly Connect. Here are the details:
Current Setup:
- Trigger: New Order from Yampi
- Actions: Create Contact and Add Tag in Systeme.io
- All connections are properly authenticated and showing as "connected"
Issue Description:
- The integration works perfectly in test mode
- All test runs are successful and data flows correctly
- However, in real production environment, no data is being transferred
- No error messages are being displayed
- The automation appears to be properly configured but isn't triggering with real orders
What I've Already Checked:
- All connections are active and authenticated
- Permissions are properly set
- Webhook URLs are correctly configured
- Test runs are successful
Request:
Could you please help me investigate why the integration is not working in the production environment despite working in tests? I need to ensure that real orders from Yampi are properly triggering the automation and creating contacts in Systeme.io.
Additional Information:
- Account Name: Igor Alves Silva
Thank you for your assistance.
Best regards,
Igor Alves!
Current Setup:
Issue Description:
Request:
Best regards,
Igor Alves!
