Integration not possible
Status: Closed · Asked by Mitra Sessions on · 0 views
I signed up because I wanted to connect 2 specific apps - Thrivecart and Systeme.io. On the Pabbly sales page it suggests I can connect them, but now I've signed up there is no option to integrate these 2. Am I doing something wrong or do I need to cancel and use Zapier (who do integrate them).
Can you please confirm which application you want to use in the trigger and action step between Thrivecart and Systeme.io application?
Thanks for getting back to me. I’m trying to set up that if someone purchases in Thrivecart they get added to Systeme and a login is generated for them. But I can’t connect any actions between Thrivecart and Systeme. Systeme doesn’t appear as an option of an app I can connect to (and vice versa, if I begin with Systeme, Thrivecart doesn’t appear as an option)
Hey @Mitra
As of now system.io action events are not available on the platform but you can post a request for the same here - https://pabbly.hellonext.co/
Our Integration will look into the possibility of it and try to add the action event accordingly.
