Integration Problem
sagarneogi
Facing Problem in integration. Please see the attachmnet
Hey @sagarneogi
Please share your concern in detail along with the workflow's name and usecase, so we can look into it and assist you accordingly.
sagarneogi
Hello
work flow name - MED ASTRO FB
PABBLI & SWIPE PAGES INTEGRATION
Files attached of screnshots
Hey @sagarneogi
Could you please recapture a webhook response once by passing a submission from your live swipe page?
I tried to integrate My SendinBlue Form with Pabbly but it only picks the Email ID. Doesn't Pick up the Name and Number. Please help . I need to purchase the Subscription ASAP
Hey @sagarneogi
The attachment which you have shared is not accessible, further please check the same with the Swipe Page team as well.
Also, the Swipe Page trigger is based on Webhooks. Pabbly Connect captures any webhook that is sent to it.
If your event is not arriving and not getting captured inside Pabbly Connect there is a good chance that it is not being sent to Pabbly Connect. In cases like these, you will have to contact the Swipe team to see why your event is not being sent from Swipe Page.
To double check, you can also confirm it through a webbooks testing site by the name of webhook.site.
You can copy the webhook URL provided by Webhook.site inside Swipe Page and do the test event inside Swipe to see if the webhook is being captured on not inside Webhook.site. This will double-confirm the issue.
Here is a sample video that you can follow to track the webhook issue:
Hey @sagarneogi
Please contact the Swipe Page support team and can test the same on the Webhook.site
