Integration with Tave or Scoro
Status: Open · Asked by melissademple on · 0 views
melissademple — Question ·
I'm using a quotation and contract signing software that does a few more amazing things and I'd like to be able to integrate it with Systeme.io. You do not currently have this as an option in your apps library. I even went in search of another software that does what Tave does and I found Scoro but you don't have that one in your library either. What is the likelihood that you can add either of those any time soon?
Thanks,
Melissa
Hi @melissademple,
If you want a particular application to be added to Pabbly Connect, you can submit your request on our dedicated platform: https://pabbly.featureos.app/b/Integration-Request
Our integrations team will review your request and, if possible, add the desired application to Pabbly Connect.
In the meantime, if any of these applications support webhooks, you can use Webhook by Pabbly to set it up as your trigger application and capture the data.
youtube.com/watch?v=FRkl5R7-Ls0
