leocmarques
Hello, I can't create an automation with Infinity triggers. When I choose a trigger event (I've tried all of them), the only response I get is "Invalid Scope(s) provided." and no data is received, even if I create an item/comment on Infinity in the selected board.
Could you check that? (workflow Infinity -> Gestão Click -> Infinity)
Also, is it possible to select a specific folder inside the board, so only the items created in this folder will trigger an event?
Thanks in advance!
Thanks in advance!
