IP address (or range) for white listing
Status: Closed · Asked by flauwer on · 0 views
Hi there,
I use pabbly to send information to a API endpoint.
However, for security reasons, I need to white list the IP no. of the POST webhook API (or range of IP no.s).
What is the IP range of Pabbly Connect POST webhooks?
Best regards,
Thomas
Hi there,I use pabbly to send information to a API endpoint.
Best regards,
Thomas
Here's the Pabbly Connect IP - 44.224.102.169
HelloI have a Problem when I send data API:
Error of the SERVER:
IP 2600:1f13:7cb:8700:e267:288:f429:3cf4 not allowedThe support of the server:
"The IP of affiliate is correct 44.224.102.169 but their network/server go out with another IP. This IP is IPv6, but we need IPv4."It is possible to place a field or command to send another IP?
Thank you
It's Solved!! thank you
