Is freshsales integration in pabbly for Freshsales or Freshsales Suite?
Status: Closed · Asked by egorders on · 0 views
Freshsales has two products , Freshsales(icon without plus sign) and Freshsales Suite(icon with plus sign).
Which one is integrated in pabbly connect, can you confirm?
We are having a conversation with the Freshsales team regarding the same and shall notify you once we have an update for you.
Any updates on this
Any reply from Freshsales team
Freshsales has two products , Freshsales(icon without plus sign) and Freshsales Suite(icon with plus sign). Which one is integrated in pabbly connect, can you confirm?
Both are integrated with us.
Freshsales Integration - https://www.pabbly.com/connect/integrations/freshsales/
Freshsales Suite Integration - https://www.pabbly.com/connect/integrations/freshsales-suite/
We are trying to get Freshsales Suite integration working with Pebbly Connect, unfortunately we are not getting any options to map fields and if we test we get the below error (see attached):
<html>
<head><title>405 Not Allowed</title></head>
<body>
<center><h1>405 Not Allowed</h1></center>
<hr><center>nginx</center>
</body>
</html>
Any inputs will be highly appreciated. Thanks.
Hey @JosephJ
It looks like you might not have connected your "Freshsales" account correctly and because of that, you are having such an error.
Kindly re-connect your FreshSales account as mentioned in the help text and try again.
My connection looks just like the one in your screenshot. Please note that we also have a custom domain configured (pipeline.companydomain.com), however I’ve provided the Freshsales subdomain as per the instructions still no luck
Hey @JosephJ
Kindly create a new thread regarding your concern. So that we can look into it and assist you accordingly.
