Is it possible for Pabbly Connect to retrieve custom field data from ActiveCampaign?
Status: Closed · Asked by Cheryl Spencer on · 0 views
C Spencer — Question ·
I don't see any custom fields when I use the Search Contact action.
Fagun Shah — Reply ·
Active Campiagn API does not let you search using custom field values, did you find this functionality in any other integration software
Fagun Shah
- Automation Freelancer
