Is it possible to fetch Facebook Ads budget and spend data using workflows?
Status: Open · Asked by kunal.remysez on · 0 views
Hey @kunal.remysez
For your use case, you may find the following video lesson useful for processing Facebook Lead ad data.
Hey @kunal.remysezFor your use case, you may find the following video lesson useful for processing Facebook Lead ad data.
I dont see Facebook Ads insights under my available options ...
I assume I need to upgrade?
Which upgrade tier do I need?
@supreme.95 ?
We have created a new action step with several advanced fields to retrieve accurate Facebook Ad Insights metrics for your ads. Please test it and let us know if it meets your needs.
And here is the documentation to use the action step. - https://forum.pabbly.com/threads/facebook-ads-inside.23346/
Hi Supreme,
I dont get Facebook Ads insights in the 1st step :/
https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTY0MDYzNDA0MzE1MjZmNTUzMDUxMzci_pc
No, the Facebook Ads Insights trigger event is not currently available in the integration. Could you please provide a reference for the use of Facebook Ad insights so that we can explore the possibility of incorporating it?
I want to include the ads spend and budget in the reporting.
Please check the following threads related to the Facebook Ads action step to get the relative details.
I think you are not understanding what I have been saying.
I can't select Facebook Ads Insights, as mentioned in the link, because I don't get the option to select it.
I already shared the screenshot twice with you.
Do you now understand the issue?
Do you see Facebook Ads Insights mentioned in the available apps below?
As mentioned previously, we currently don't have Facebook Ads Insights as the trigger step (first step). If you want Facebook Ads Insights to be added as a trigger step, you can submit your request on our dedicated platform.
https://pabbly.featureos.app/b/Update-Existing-Application
Our integrations team will review your request and, if possible, add the desired trigger step to Pabbly.
