Is it possible to remove + signs in an UTM parameter using Text Formatter's Extract Pattern?
Status: Closed · Asked by Benjamin Chew on · 0 views
I'm not a regex dev, so i'm confused here. I think it's possible.
Hi @benjaminshuu,
You can try using the 'Replace Text' feature to replace the + sign with the value of your choice.
Thank you!
