Is system down?
Status: Open · Asked by Doc Alvarez on · 0 views
I try to add fields in Google Sheets and the fields are frozen and cannot add into them like I have many times.
This is where I try to add the info in the fields into google sheets and it appears frozen.
Hi @DocApply,
Please share the Workflow URL in which you have this concern.
Hi @DocApply,Please share the Workflow URL in which you have this concern.
https://connect.pabbly.com/workflow/mapping/IjU3NjUwNTY5MDYzNTA0MzY1MjZjNTUzNDUxMzYi_pc
The issue appears to be related to the large amount of data captured from the Pexels action steps, which is slowing down your workflow. I suggest you add a Data Forwarder as the last step in this workflow and send the necessary data to a different workflow where you can add the remaining steps. This way, you can distribute the load across two different workflows and avoid this issue.
